So in a few months or so i intend to upgrade to this build:
https://uk.pcpartpicker.com/list/nrKwZ8
I am happy with the parts, the price and the performance considering i do both gaming and lots of graphical and motion editing.
The only problem is for whatever reason the motherboard (Asus PRIME X370-PRO ATX AM4 Motherboard) is not compatible with the CPU cooler (Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler).
It says on the site "The Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler may require a separately available mounting adapter to fit the Asus PRIME X370-PRO ATX AM4 Motherboard"
I am very new to PC builds and components and honestly i had no idea there was such a thing as a "mounting adapter" beforehand. If someone could link me to the correct mounting adapter or change the
build so that there are no problems, please keep in mind i DO NOT want water cooling, that would be great!
Thank you.
https://linustechtips.com/topic/767769-compatibility-issues/
Mounting kit:
http://www.cmstore-usa.com/amd-am4-upgrade-kit-rr-accy-am4b-r1/
212 Evo is not exactly a nice cooler. I'd get a Cyrorig H7, H5 or R1. They perform much better while having better temps. Also Noctua NH-D14/D15 and Be Quite Dark Rock 3/Dark Rock Pro 3
https://linustechtips.com/topic/767769-compatibility-issues/#findComment-9694117
Just now, Himommies said:
bruuuuh a c7? and still you haven't got rid of compatibility issue
Quote
The CRYORIG C7 40.5 CFM CPU Cooler may require a separately available mounting adapter to fit the MSI X370 GAMING PRO CARBON ATX AM4 Motherboard.
https://linustechtips.com/topic/767769-compatibility-issues/#findComment-9694124
2 minutes ago, JoonesBP said:
@deXxterlab97 ok i will change it to the H7 but will that mounting kit work for the H7 too?
no.
coolers from before Ryzen's lauch don't work with Ryzen, so you need to contact the company and have them send you a mounting bracket so the cooler fits onto a Ryzen socket. simple as that.
nearly all coolers need this mounting bracket as stock hasn't been updated yet.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/767769-compatibility-issues/#findComment-9694136
3 minutes ago, deXxterlab97 said:
No that mounting kit is for Cooler Master 212 Evo only
You will need this http://www.cryorig.com/getam4.php
So if i buy the cooler, collect proof of purchase and then request an upgrade kit, they will send one to me and it will be compatible?
https://linustechtips.com/topic/767769-compatibility-issues/#findComment-9694151
The BQ! PureRock 3 fit my X370 R7 without any need for a special adapter. fit right to the AM4 tabs.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/767769-compatibility-issues/#findComment-9694159
1 minute ago, JoonesBP said:
I cannot find the Pure Rock 3 on PC Part Part Picker even with the compatibility filter off.
https://uk.pcpartpicker.com/product/cwPzK8/be-quiet-cpu-cooler-bk009
System specs:
https://linustechtips.com/topic/767769-compatibility-issues/#findComment-9694170
  • be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler and AMD RYZEN 7 1700 3.0GHz 8-Core Processor are not compatible.
  • be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler and MSI X370 GAMING PRO CARBON ATX AM4 Motherboard are not compatible.
https://linustechtips.com/topic/767769-compatibility-issues/#findComment-9694174
to which i first say ALWAYS REMOVE FORMATTING WHEN PASTING TEXT BECAUSE I CANNOT READ THAT (dark theme user)!
and secondly, i say bull-shitty-mcDah it doesn't fit. I have one, it fits on the AM4 tabs and is supported by the manufacturer.
System specs:
https://linustechtips.com/topic/767769-compatibility-issues/#findComment-9694185
Just now, knightslugger said:
to which i first say REMOVE FORMATTING WHEN PASTING TEXT BECAUSE I CANNOT READ THAT (dark theme user)!
Ok sorry about the formatting xD
I will look into it i am interested now
https://linustechtips.com/topic/767769-compatibility-issues/#findComment-9694189
