So I was getting wierd temps
68 in one core and 79 on another  set full load, I took the cooler off and reapplied paste under the ihs and then on top of the ihs
turned pc on, no boot but cpu light is on on my mother board all the fans spinning etc
i can can not have damaged anything I was supper carful
please help me trouble shoot,
i have rest cmos I think and pressed the bios reset button on the back of the board and it's still the same
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/767354-pc-not-bootin-again-please-help/
25 minutes ago, airdeano said:
reconnected the 8-pin PSU harness?
What's that ?
U mean I should take the 8 pin out and put it back in ? The big 8 pin thing at the top left of the CPU socket ?
also (1600)
 What do you mean please
also (1600)
Only need to put thermal paste on the CPU, no need to put on the heatsink.
Recoinnect CPU power as stated by airdeano,
Also maybe try re-seat RAM
It's delidded so I had to do under and on top of the ihs
also (1600)
9 hours ago, airdeano said:
yes, the 8-pin EPS connector (the one that is usually in the upper left corner).
Tried it and still nothing :(
also (1600)
Did you check for physical damage after delidding? The adhesive intel uses between the die and ihs is dog shit so I understand why you'd delid but still risky!
Well long story short I dropped the CPU after delid and broke off 4 capacitors
but a shop repaired them for me and it had been working since
also (1600)
