PSU, Case... etc Cables
Solved by Guest,
Front panel connector, front audio and USB comes with the case to connect
Chassis instrusion is not needed afaik
As for PSU:
PCIE connects to GPU
ATX/EPS connects to mobo
and SATA power connects to storage like HDD, SSD and ODD (optical drive). Do note you also should need to connect SATA DATA from mobo to them too (mobo should come with 2 sata data)
And the ATX/CPU Power comes from PSU too
Speaker/buzzer iirc is for error sound/beep
