laptop for work
Go to solution Solved by elguito,
thanks for everyones help. I decided to recommend this http://www.ncix.com/detail/lenovo-ideapad-100-pentium-n3540-55-129956.htm?promoid=1729 and he just got one on sale for almost $200 off the regular price
my dad recently asked me for help finding a laptop that he can use for accounting purposes and word processing he has set a price limit of $500 Canadian and the location for buying the laptop is the lower mainland in BC windows 7 or 10 preferred any recommendations would be great because there are a lot of different choices out there
edit he requested the laptop be 15 inches
https://linustechtips.com/topic/765835-laptop-for-work/
what software does he use? That aside any i3,i5,i7 will do.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/765835-laptop-for-work/#findComment-9672554
I just did a quick search on BestBuy and couldn't find anything locally. The only stuff I found that would fit the bill were refurbished Dell Latitudes, HP ProBooks, and Lenovo ThinkPads. Not sure if he'll be into that since they would be shipped to him. It's sort of a odd time to be buying a laptop which is why there isn't much in terms of good deals.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/765835-laptop-for-work/#findComment-9672617
couple of dollars over budget but you get a 15.4", full hd, i3 6100U laptop for around $500 Canadian.
https://www.amazon.ca/Asus-F556UA-AB32-Full-HD-Laptop-Windows/dp/B01LX0KIGB/ref=pd_cp_147_3?_encoding=UTF8&psc=1&refRID=TNZX30BRCT71PSS0S16S
Now if you are a student and have a student email, you can get this from the Microsoft Store. It's 13", not 15 but it's a signature edition so no bloatware and it's a 2 in 1, so has a tablet mode.
https://www.microsoft.com/en-ca/store/d/dell-inspiron-13-i5368-signature-edition-2-in-1-pc/8nzpxlr1djw0/
https://linustechtips.com/topic/765835-laptop-for-work/#findComment-9672657
it is called a used ThinkPad or EliteBook
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/765835-laptop-for-work/#findComment-9672847
you could always check at free geek or comparable stores
http://www.freegeekvancouver.org/
https://en.wikipedia.org/wiki/Free_Geek#Locations
i know my local free geek in the US has a laptop room. with friendly staff to help you pick out one that fits your needs and budget perfectly.
https://linustechtips.com/topic/765835-laptop-for-work/#findComment-9674540
