So I just replaced a fried asus b350 prime in my system with the same  model just a new one. I don't know how I go about booting It up? Do I reinstall windows to the same drives I had? How does it work? The ssd already has windows on it I just don't know how to go about and booting it up correctly.. please help!
https://linustechtips.com/topic/765825-new-mobo-same-system/
booting? just turn on your pc and if its good its good, if windows doesn't load youll have to reinstall it.
people will say do a new installed no matter what usally (and it is a good idea), but when i changed my mobo windows still worked and i never fresh installed and to this day i have no zero issues
Smoking weed at the red light like its legal
https://linustechtips.com/topic/765825-new-mobo-same-system/#findComment-9672429
Well it goes straight to bios and it recognizes both of my drives. But do I just change the boot location then?
https://linustechtips.com/topic/765825-new-mobo-same-system/#findComment-9672452
yeah just boot from the drive you have your OS on and if it works just set that as first in the boot order
https://linustechtips.com/topic/765825-new-mobo-same-system/#findComment-9672455
Let's say I do a new install of windows, does everything I have in those drives get deleted? Or what happens to the os that was already in the ssd?
https://linustechtips.com/topic/765825-new-mobo-same-system/#findComment-9672504
well youll want to wipe the drive 100% and then install windows again, so back it up if you have to
https://linustechtips.com/topic/765825-new-mobo-same-system/#findComment-9672518
