Any reason why ryzen? Also get a kinguin key for windows for around $30
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9670943
One change that I strongly recommend is getting a 1600 instead and using its stock cooler.
PCPartPicker part list: https://pcpartpicker.com/list/mh7nr7
Price breakdown by merchant: https://pcpartpicker.com/list/mh7nr7/by_merchant/
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  ($218.67 @ OutletPC)
Motherboard: Asus PRIME B350-PLUS ATX AM4 Motherboard  ($98.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($69.99 @ Amazon)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($42.49 @ Amazon)
Video Card: MSI GeForce GTX 1050 Ti 4GB Video Card  ($148.99 @ SuperBiiz)
Case: Corsair 270R ATX Mid Tower Case  ($54.99 @ Amazon)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($36.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($89.98 @ NCIX US)
Wireless Network Adapter: Rosewill RNX-N150PCe PCI-Express x1 802.11b/g/n Wi-Fi Adapter  ($11.89 @ OutletPC)
Total: $772.98
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9670960
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: ASRock AB350 Pro4 ATX AM4 Motherboard  ($89.99 @ SuperBiiz)
Video Card: Asus Radeon RX 480 8GB ROG STRIX Video Card  ($214.49 @ OutletPC)
Case: Corsair 200R ATX Mid Tower Case  ($54.98 @ NCIX US)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($48.89 @ Newegg)
Other: Windows from Kinguin for like $30 ($30.00)
Total: $806.27
Generated by PCPartPicker 2017-04-12 18:44 EDT-0400
IT'S ALL AMD OR NO AMD
idk
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671006
Total: $806.27
What about the AMD ssd? ?
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671027
3 minutes ago, Droidbot said:
no budget
but if we went with that, I'd go AM3+ and get radeon RAM as well
(PaperLuigi)
I'm just glad that 1050 ti was replaced with an rx 480. That choice had me chin scratching.
There is enough youth in this world, how about a fountain of smart?
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671053
Just now, crzyces said:
(PaperLuigi)
1050Ti is a shit chip for PCs without auxillary power connectors. Because who wouldn't put in $20-40 more and get yourself a superior card by every means
idk
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671058
3 minutes ago, spenfur said:
why is that the 1060 is better
I disagree. I watch lots of benchmarks too. You'll notice, quite often, the power draw on the 480 is low, while the stock 1060's are often overclocked. Also, they tend to avoid games like Resident Evil 7 and such where the rx470 can edge out the 1050. Vulkan enabled games are NEVER (well almost never) tested with it. 9x out of 10 they will disable options that the 1060 struggles with that the 480 handles fine.
Is the 480 leaps and bounds better? No, they still trade blows, it's just now the 480 is connecting with solid left hooks while the 1060 is landing a stiff jab.
It's tough to find nuetral sites, as most seem to be run by fan boyz of one or the other, but in nuetral sites, the 480 normally edges out the 1060 about 60% of the time, and when it loses (except in GTA V) the margin is normally smaller.
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671099
yes ive see that alot
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671125
47 minutes ago, spenfur said:
why ryzen is because im after more of a multi purpose build
I've yet to be convinced that AMD is better for multi-purpose machines.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671143
my preference is AMD  because i use a lot of cores and threads for school work. trying to use only 2 cores for the past two years has more then killed my pc
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671221
I don't remember the last time my 6 core ever got fully utilized outside of Cinebench. And I'm studying Computing Science...
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671231
i render my A/V projects, research for essays, and listen to music all at the same time and im in computer sience
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671242
get os from reddit for $20-30.
Motherboard: ASRock AB350M-HDV Micro ATX AM4 Motherboard  ($69.99 @ SuperBiiz)
Memory: ADATA XPG Z1 16GB (2 x 8GB) DDR4-2400 Memory  ($86.48 @ NCIX US) faster ram if you can afford it.
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($80.88 @ OutletPC)
Video Card: Asus Radeon RX 480 4GB Dual Video Card  ($188.99 @ SuperBiiz)
Case: Rosewill FBM-05 MicroATX Mini Tower Case  ($22.99 @ Jet)
Total: $771.27
Generated by PCPartPicker 2017-04-12 20:37 EDT-0400
https://linustechtips.com/topic/765692-building-a-pc/#findComment-9671448
