I finally got my ryzen 1600
IMG_0672.thumb.JPG.6d5eecc165f22fc6d849b5e4ed1e71f3.JPGRyzen 5 1600
8gb ddr4
asus dual rx 480
750 watt power supply
better then my no case build :)
any one gotta good good way to hold up leds
i still need to get my white extensions for the poweersupply and a white cpu cooler
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/765616-first-half-decent-pc/
glue tape blue tac magnetic led strips
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/765616-first-half-decent-pc/#findComment-9669961
13 hours ago, deXxterlab97 said:
What psu?
a cheap EVGA
Peripherals
https://linustechtips.com/topic/765616-first-half-decent-pc/#findComment-9670013
13 hours ago, Nmistry09 said:
Is your ram supposed to be in the 4th slot? That doesn't seem normal.... Or is that the first slot, and I'm just crazy?
its the 4th idk why i put it in the 4th but i did
Peripherals
https://linustechtips.com/topic/765616-first-half-decent-pc/#findComment-9670064
Make sure you turn your computer off when you reinstall it as well. Lastly, why is the first slot (for RAM) opened? That really messes with my OCD... You should probably close that. I don't think it's a good idea to leave that open, it might break that slot.
https://linustechtips.com/topic/765616-first-half-decent-pc/#findComment-9670082
Na it will be fine im not taking the glass of intel i get my other 8gbs of ram
Peripherals
https://linustechtips.com/topic/765616-first-half-decent-pc/#findComment-9670103
