3 minutes ago, Courage the Cowardly Dog said:
Is it safe to connect an 8pin connector to a 10pin slot? or a 24pin connector to a 10 pin slot?
What kind of a 10 pin slot? Most likely the answer is no
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/765526-will-it-fit/#findComment-9668845
I wouldn't think so. They make them so they don't fit, so you don't break your computer. An 8 pin should go in an 8 pin slot, a 10 pin in a 10 pin, etc.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/765526-will-it-fit/#findComment-9668846
I was thinking of getting an adapter. I want to upgrade my GPU but I only have a 250w power supply. Any ideas?
https://linustechtips.com/topic/765526-will-it-fit/#findComment-9668861
1 minute ago, Courage the Cowardly Dog said:
10 pin slot for a 10 pin connector to power the motherboard
What mobo is this?!?
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/765526-will-it-fit/#findComment-9668876
Just now, Courage the Cowardly Dog said:
It's hard to identify it. It's a Lenovo PC but whenever I try to search for the mainboard given by CPU-Z, I cant seem to find it. It says its a Lenovo Skybay
Probably a custom power connector then. Not gonna work then unless you swap the psu and motherboard :/
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/765526-will-it-fit/#findComment-9668924
2 minutes ago, Courage the Cowardly Dog said:
Lol I was planning on buying the PSU, I was making sure if it was safe to use an adapter
im using adapter but for 6pin. and no problem with that but idk i cant say yours will work for sure. better get a good psu with the connectors you need would be my advice. wouldnt risk a brand new card.
AMD Phenom II X6 1055T |Asus M4A88T-M |A-DATA 8 GB(4x2) @1333|Asus R7 360 2G OC|Asus TA-M1|Hitachi 7211 1TB|Fortron 460W|Windows 10 pro 64
https://linustechtips.com/topic/765526-will-it-fit/#findComment-9668990
5 minutes ago, Courage the Cowardly Dog said:
that's a really odd propriety connector from lenovo, some digging
http://www.tomshardware.com/answers/id-2924190/pin-power-supply-motherboard.html
So it uses 10pin but does it use a long 24pin? Because there are adapters for that but not sure if they'll work properly
https://linustechtips.com/topic/765526-will-it-fit/#findComment-9669057
Yea I was also looking through the Toms Hardware Forums and found the best answer was to get an adapter or another best answer was to not get an adapter
https://linustechtips.com/topic/765526-will-it-fit/#findComment-9669104
