Front Panel Connector Confusion
Solved by Guest,
Nope, LEDs can oriented only one way. Normally the black or white cable is the ground (-) one, and the colored is the positive (+) one. However, if the cables aren't colored, just put the connector on one way - if the LED works, you're good to go, if not, just turn it upside down, it should work now.
1
5
1
toxic_worper ·
9
1
voltigeurramon ·
Posted in Troubleshooting2 -
1
1
