Hello guys I'm building my very first budget gaming PC.
And with the lunch of the new Ryzen 5 I thought this:
https://pcpartpicker.com/user/Kilo_One/saved/ZzgmGX
let me know what do you think, what would you change
and if I can use it for playing at 1080p, 60fps, ultra-high settings,
anti-aliasing on, and also can I upgrade it in the future ???
https://linustechtips.com/topic/765088-ryzen-build-help/
this is fine will work at 1440p 60hz as well will go 144hz but not in all titles
note get a 8gb 480 not a 4gb
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/765088-ryzen-build-help/#findComment-9664248
So the good news is if you get a 350 motherboard you should be set for a while if you go Ryzen, as the chipset/platform is supposed to be the same for the next 4 years. I5 build would be better in terms of pure gaming however.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/765088-ryzen-build-help/#findComment-9664249
problems-nope, looks good. 1080p-check. 60fps-check. ultra-high settings-maybe, depends on the game w/aa-again depends on the game  upgradeable in the future-big check
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/765088-ryzen-build-help/#findComment-9664254
You'll be fine with that. I have the 8GB RX 480, with an R7 1700x, and my gaming is a great experience at 1080.
https://linustechtips.com/topic/765088-ryzen-build-help/#findComment-9664259
I'd get a 8GB 480 for future proofing, rest is fine
https://linustechtips.com/topic/765088-ryzen-build-help/#findComment-9664293
