Hey guys I recently bought a Samsung SA100N 19inch LED and at first it was working fine but when went into its menu i hit auto adjust and now @ its maximum resolution which is 1366x768 then screen shows a black bar at the right hand side and what ever Iam trying it doesn't get fixed i try re auto adjusting that didn't work re installing my Gpu drivers,trying to get the software magic tune to work on Win 8.1 but it doesn't work so guys can help me out .
Intel Core i5 4670k,ASUS B85-MG,4GB Vengeance,Gigabyte 7950,Cooler Master Elite 430 Black,Cooler Master 600 Silent Pro
https://linustechtips.com/topic/76495-resolution-problem/
Did you set your aspect ratio in the menus too? If that doesn't fix it, what's your resolution set to in windows?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/76495-resolution-problem/#findComment-1049612
but the problem is when i put it at maximum resolution it shows a black line at the right hand side of the screen and auto adjust isn't fixing it
https://linustechtips.com/topic/76495-resolution-problem/#findComment-1049692
