what is the hotkey to make more then one key the same color. i had it working but i forgot it it was holding CTRL, Shift or ALT.  I tried holding each one and clicking to change the colors but it doesn't work. idk if its my keyboard not registering that im holding the button or what?
Smoking weed at the red light like its legal
https://linustechtips.com/topic/764871-corsair-cue-help/
I'f you hold control you can "highlight" keys, then you select a color for those highlight keys.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/764871-corsair-cue-help/#findComment-9661820
you can do it one by one too, like hold ctrl as you say and just click the keys one by one. i tired that and it didnt work, i even restarted the softwear. i never changed any binds dont even know how
https://linustechtips.com/topic/764871-corsair-cue-help/#findComment-9661831
It's working for me *shrug*
https://linustechtips.com/topic/764871-corsair-cue-help/#findComment-9661847
it did work for me then it just stopped, my ctrl key does work too as i tested it in games.
restarted my pc and everything, guess time to reinstall CUE
https://linustechtips.com/topic/764871-corsair-cue-help/#findComment-9664491
