Hi everyone,
My little sister, 10 years old, wants a new mice. She is currently using the Apple magic mice but she doesn't like that one. Can someone recommend me both a cheap and a expensive mice? She will use it for normal use and a little bit of gaming.
Thanks!
EDIT: she has small hands so she needs a small mice if possible.
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/764383-small-mice-for-sister/
This might be a little overkill for your price range, but my sister uses the MX Master. She has very small hands and absolutely loves it.
I spend most of my time on Autodesk and Caffe. CAD is great, as long as you know what you're doing.
Watson: Ryzen 7 1800X, 32GB 3000Mhz Dominator Platinum, X370 MSI Pro Carbon, 2x FirePro W9100s, 2x 256GB Samsung 850EVO SSDs, 2x 6TB WD Raid 1 HDDs, Ghetto Custom Cooling and Case, Logitech G910 and G502, 3DConnection SpacePilot Pro, 6x 27" Viewsonic FHD Monitors, 2x 24" Acer FHD Monitors, Windows 10 Pro/Ubuntu 16.04 Dual.
Yes, you can game on FirePro Cards, it's just overkill if you never use it's full abilities.
Sherlock: 128 Core Render Server (32 Nodes, Matched Core 2 Quads, 8GB DDR2) running HPC Service Pack 1 on Windows Server 2016. Just because, you know, who doesn't want to render in real time? (Plus I don't pay the power bill)
https://linustechtips.com/topic/764383-small-mice-for-sister/#findComment-9656024
