I recently brang back an old laptop of mine (6700HQ no GPU, Win 10 64 bit(by old I mean slow)) and twice in a week I got a blue screen that said: IRQL_Not_Less_Or_Equal. I have no idea why this is happening. I did change the integrated graphics setting a bit, but I doubt that't the reason. If you need more information, tell me.
https://linustechtips.com/topic/764349-irql_not_less_or_equal/
somethings corrupt. To lazy to explain so went to toms hardware
http://www.tomshardware.com/faq/id-1653275/fix-irql-equal-error-windows.html
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/764349-irql_not_less_or_equal/#findComment-9655548
1 minute ago, ArcherTechTips said:
I set the performance to not care about battery and highest performance. I really don't know if that matter though.
doesnt affect it
https://linustechtips.com/topic/764349-irql_not_less_or_equal/#findComment-9655550
Just now, Perbox said:
to late
ninja'd
https://linustechtips.com/topic/764349-irql_not_less_or_equal/#findComment-9655553
Use BlueScreenView to find the root cause.
Please don't allow Tom's Hardware to shill the shitty SlimCleaner scamware to uneducated consumers.
idk
https://linustechtips.com/topic/764349-irql_not_less_or_equal/#findComment-9655569
i didnt even look at it xD
https://linustechtips.com/topic/764349-irql_not_less_or_equal/#findComment-9655577
Follow the BSOD posting instructions pinned at the top of this subforum.
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
https://linustechtips.com/topic/764349-irql_not_less_or_equal/#findComment-9656441
