Hi
I build a PC for my friend which has R9 270x graphics card. The PC is working for 10 days now and it has some problems.
I would like to say that PC is stable it passed stress tests ok. And after 1-2 days of use by my friend he complained that his LoL graphics is strange. I quickly fix that by resetting driver to default. Next day he complained that he sees thin horizontal lines on his screen. I tried everything except “korean” msi bios update. The thing is that PC and my friend is in another city and components are bought in my city and I can’t easily go to him and try something else or even bios update. And I am not comfortable to let him do it because he does not have any skill in that sort of stuff.
My question is are any of you had that issue with R9 series cards. Do you know a fix, though I am quite aware that it is a bios or driver problem. And we just need to wait.
But it is not my PC. I build it for a friend who paid for it, and now it is not working properly and it is an awkward situation for me.
CPU: INTEL Core i5-4670 (3.40GHz, 1MB, 6MB, 84W, 1150) Box, INTEL HD Graphics 4600
MBO: Asus B85M-G
RAM: Corsair DDR3 1600MHz 8GB (2x4GB), Vengeance,Unbuffered, 9-9-9-24, CMZ8GX3M2A1600C9
GPU: Sapphire AMD Radeon R9 270X 2G GDDR5 PCI-E DVI-I / DVI-D /HDMI / DP DUAL-X WITH BOOST & OC VERSION, 1020MHz(1070MHz) /1400MHz, 256-bit, 2 slot active, , LITE
PSU: 600W Corsair GS Series, ATX PSU, ATX12V v2.31, 85%
HDD: HDD SATA III 1 TB WD Caviar Black,3,5", 7.200 rpm, 64MB, WD1002FAEX
COOL: ANTEC H2O 620, CPU hlađenje, socket 2011/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1
CHAS: COOLERMASTER Silencio 352 Matte, SIL-352M-KKN1, mATX, USB 3.0
https://linustechtips.com/topic/76422-r9-270x-problems/
In terms of the AMD card, you definitely need to continually be updating drivers, as AMD is not known for their good drivers.
PC Specs:
New Compact Build
CPU: i7 8700k (Delidded)  |  GPU: EVGA GTX 1070Ti ACX 3.0 Black  |  Motherboard: ASRock Fatal1ty Z370 Gaming  |  Case: EVGA Hadron Air
RAM: Corsair Vengeance LPX 16GB DDR4 3000MHz  |  SSD: Samsung 860 EVO 1TB  |  Monitor: ASUS PB287Q
     OS: Windows 10  |  Keyboard: Corsair Strafe RGB  |  Mouse: Logitech G502 Proteus  |  Headphones: Steelseries Arctis 5
Surface Book 2 15"
CPU: i7 8650U  |  GPU: GTX 1060M  |  RAM: 16GB DDR3
https://linustechtips.com/topic/76422-r9-270x-problems/#findComment-1048530
Check cables, try a hdmi cable to tv it May be the monitor...
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
https://linustechtips.com/topic/76422-r9-270x-problems/#findComment-1050679
The r9 2xx series shouldn't support analog signals.  VGA shouldn't have worked to begin with; use a dvi cable.
First Build:| Gigabyte 990FXa-UD3 | FX 8120 4.0Ghz | Coolermaster Seidon 240M | Asus Radeon HD 7870 | Kingston HyperX 3k 120GB SSD + WD Green 2TB HDD | Corsair RM750 | 8Gb Kingston HyperX 1866Mhz CL9| Fractal Define R4 White/Windowed |
https://linustechtips.com/topic/76422-r9-270x-problems/#findComment-1061743
Don’t know about no analog signals support, he has only vga connector. And so do I and PC worked on my monitor also and I to have vga connector only (Philips 220E).
And I suppose if they didn’t  support analog signal they would not ship the card with DVI to VGA adapter.
https://linustechtips.com/topic/76422-r9-270x-problems/#findComment-1091358
