Questions about i7 6700k Temperature
Solved by airdeano,
then it is about par for the case/cooler combo. you can try to undervolt the CPU to lower the temps, but what you have now is what you got.
nuttin' really obviously wrong. usually in a spacial case with adequate ventilation, you'd have 5-8° above ambient temperature. since you are shorted the adequate ventilation, then you are fine at 12-15° above ambient.
Featured Topics
IR76 ·
Posted in Phones and Tablets0 -
1
3
SparkFox621 ·
Posted in Troubleshooting0 -
JJackson ·
Posted in Networking0 -
logan mcd ·
Posted in Graphics Cards4 -
Xtppph ·
Posted in Troubleshooting1 -
Average Nerd ·
Posted in Troubleshooting10
