Good power supply?
Go to solution Solved by Guest,
12 minutes ago, DiGiTaL FaKiE said:
My build is a ryzen 5 1600x "when available" a gtx 1060 6gb or 1070 and 16gb of ddr4
So you have a few hundred dollar cpu, a few hundred dollar gpu and an almost 100 dollat ram yet you can't afford a decent psu? Priorities right lol
Evga gq/gs/b2/g2/g3 on a high end
Seasinic s12ii/seasonic g, corsair cx450m/corsair cx550m, deepcool dqst for budget
I wouldn't trust it.
there's no brand, so I automatically assume it's the lowest possible quality.
plus, used PSUs are always worse than new ones, and PSUs are not somewhere you should skip with quality.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651795
What about this one. Logisys 550W 20/24-Pin Black Dual Fan Switching Power Supply PS550A-BK https://www.amazon.com/dp/B008MUDH28/ref=cm_sw_r_sms_apa_nJD6yb64PPN0G
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651800
About the same.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651806
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651811
what's your budget and the parts you're gonna use the psu with?
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651812
1 minute ago, JDE said:
If I'm going to pay that much I'm going to get a evga 500 watt, but what about this one? Thermaltake TR2 600 Watt ATX12V v2.3 SLI Ready CrossFire Ready 5 Year Warranty Power Supply https://www.amazon.com/dp/B0058FAYQ2/ref=cm_sw_r_sms_apa_lQD6ybGZ8X1HV
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651820
4 minutes ago, JDE said:
Sorry I meant to link this one
 https://www.amazon.com/dp/B0058FAYQC/ref=cm_sw_r_sms_apa_7SD6yb9FS69P8
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651822
god, please don't pair those parts with a shitty PSU. bad PSUs can very likely damage your components if they fail. get the s12ii 520w at least.
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651852
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651864
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651865
"I wanna buy a Lexus, a 3 story house, have 4 kids, and we'll live off of rice and beans until I can afford to send them to private school"
You have your priorities all backwards. Every PSU you've asked about has been utter garbage. As another user mentioned, the 520W Seasonic is the very cheapest unit you should get and it's better by far than the cheap EVGA units.
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651947
Welp I'm guess I'll spend like 50 to 60 on one. What you think I should get hmm? And if I need a more expensive then a 60$ one then what?
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9651956
at that budget seasonic s/m12ii and corsair cx450m are good options.
https://linustechtips.com/topic/763991-good-power-supply/#findComment-9652249
