Ok this is really starting to confuse me.
For the past couple of weeks my PC has shut down when playing Rocket League online and only this game online. Event viewer records it as a Kernel Power Event ID 41.
I have tried the following:
Reinstalling the game
New, more powerful PSU
Removing GPU overclock
Reducing CPU overclock
Removing RAM overclock
Replacing thermal paste on GPU
Different versions of Windows
Reinstalling graphics drivers
Specs:
FX 6300
MSI 750ti
Crucial 16gb ddr3
Super flower 850w PSU (550w Corsair before replaced)
Kraken x52 cooler
https://linustechtips.com/topic/763888-kernel-power-event-id-41/
Have you tried updating your bios?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/763888-kernel-power-event-id-41/#findComment-9650763
event 41 normally just states an unexpected shutdown (power loss... Not shutting down properly, it's just a generic event ID)... Check power lead for any visual damages, try plugging in another socket or use another extension (if you are using one)...
I'm going to put a link to my PC specs which actually aren't my PC specs and I cry myself to sleep everyday so I can have these PC specs but I can't afford these PC specs so PC specs PC specs PC specs PC specs PC specs PC specs.
https://linustechtips.com/topic/763888-kernel-power-event-id-41/#findComment-9650771
