how much money you have
do you want a tiny bit better temps or silence?
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648738
Just now, flips2K said:
For temps = AIO, Air = Silence? xD Better to go with an AIO and lower the RPM on idle xD no?
i mean under load, iirc air is a tiny bit quieter :P
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648748
Under load temps.
liquid coolers usually out preform air coolers, but are a tiny bit louder
the real question here is how much money do you have to spend on a cooler.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648752
Depending on budget my recommendation changes drastically.  If you can afford it I'd definitively recommend a Kraken X62 or X52
If they are out of your budget Noctua Cryorig and Be Quiet! have great Air coolers
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648757
4 minutes ago, flips2K said:
I want to upgrade my Cooler Master T2, also i got the i7 6700K overclocked to 4.5Ghz.
Should go for an AIO or stick with other Air cooler?
High end air coolers can be very effective and competitive with AIO.
I tend to think of an AIO as nothing more than something that buys you time.  It simply delays the eventual rise in temps.  Due to the fact that they are very small closed loops, temps will eventually rise to just a little lower than that of higher end air coolers.  It just takes a bit more time to get to those high temps.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648763
100$ - 130$
AIO
i dont know shit about AIO coolers, so wait until theres another response sadly.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648764
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648767
Yeah, but the problem here that the store that I buying it from don't has any NZXT coolers, so only AIOs from Corsair/Antec. And Air from CoolerMaster, Noctua and such but no Bequiet sad :c
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648770
Yeah, but the problem here that the store that I buying it from don't has any NZXT coolers, so only AIOs from Corsair/Antec. And Air from CoolerMaster, Noctua and such but not Bequiet. sad :c
In that case, get this AIO from corsair if you ant AIO.  Pretty dang good performance and it will be super quiet because of the 140mm fans
https://pcpartpicker.com/product/RH2rxr/corsair-cpu-cooler-cw9060027ww
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648777
Oh also, my case is supporting only 120mm fans xD like i can get an 240mm AIO wouldn't be a problem xD
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648785
In that case I'd probably get:
This one is expandable so you can put more rads on later and even put your GPU on water eventually.
https://pcpartpicker.com/product/NfjWGX/alphacool-11285-639-cfm-liquid-cpu-cooler-11285
Best air cooler on the market
https://pcpartpicker.com/product/4vzv6h/noctua-cpu-cooler-nhd15
Some good (and good looking) Cryorig stuff
https://pcpartpicker.com/product/rwzZxr/cryorig-cpu-cooler-a40ultimate
https://pcpartpicker.com/product/xFw323/cryorig-cpu-cooler-crr1a
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648793
AIOs are also safer. If you want to hang a kilogram of metal from a few milimetres of fibreglass filled with many traces whose lengths are calibrated to a fraction of a millimetre, go ahead.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648794
Yeah, I prefer AIO's myself
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648798
Great point on the large air coolers.
I don't use either.  Just stating a fact.  AIO eventually reach the same temps as higher end air coolers during prolonged loads.  I've used AIOs in the past and they are great.  Just don't expect to fold all day and see better temps from an AIO.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648809
I definitely wouldn't bother with an AIO that was smaller than 280mm. The fact that you can take the same surface area and spread it horizontally across multiple fans, and then have the whole thing strapped to the case rather than the motherboard are why I like AIOs.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648834
thats simply nature of water. after 1h bench same temp. and water cools down slower. air coolers just spike fast and cool down fast but performance same.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648838
Exactly.  Large custom loops rarely see this problem as surface area is just too large to allow for heat soak.
Agreed.  I wouldn't use anything smaller then 280mm myself, but even it will heak soak during extended loads.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648849
What you are calling "heat soaking" is just the specific heat of the material absorbing heat. A metal heat-sink will do this too, just more instantly. One of the benefits of water is that it absorbs spikes in heat output.
It's erroneous to see any link between the specific heat capacity of water and the size of a radiator -- these are in no way related.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648873
+ you can mount AIO in front of case and get better cooling for CPU but worst for other parts. + 0.1% chance of leak. And you need specific case for aio radiator mount. AIO have very good RAM compatible.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648885
You do understand that I use water cooling myself right?   I'm not an air cooling fanboy.  I'm just trying to make sure that the OP knows that AIOs have their limitations.
They way you continue to quote me is as if you're trying to teach me something.
I use AIOs every day.  I also use a large custom loop every day.
An AIO will heat soak over time.  Simply pointing this out to the OP as AIO temps can be misleading over time.   They will continue to rise over extended periods of heavy loads to temps similar to those of high end water coolers.
https://linustechtips.com/topic/763712-air-vs-aio/#findComment-9648904
