recommendation for hard mouse pads?
feeling go lucky with a hard mouse pad after burning through countless QcK's and Goliathus' . Any recommendation? looking for something maybe under 30ish CDN. I find the aluminum a tad too expensive for what they are...just cannot justify getting one yet
NZXT Phantom | 990FX Sabertooth | AMD Phenom II 1090t | Phanteks PH-TC114PE | EVGA GTX 960  | Corsair Vengeance 8GB LP |
WD Caviar Black 500gb x 2WD Caviar Green 1TB  | Corsair AX650 | Creative Sound Blaster Z
https://linustechtips.com/topic/76366-recommendation-for-hard-mouse-pads/
Corsair MM600
CPU: FX-8350 Cooler: NZXT Kraken X60 w/2X NF-A14 FLX MoBo: Asus M5A99FX Pro Rev 2.0 Memory: 8GB G.Skill Sniper@1720 GPU: Sapphire Dual-X HD7970@1100/1500 Storage: Samsung 840 120GB(OS), Seagate Barracuda 1TB 7200 64MB PSU: Sparkle 850W Gold Case: Corsair C70 Military green w/ Solid window Keyboard: Ducky Shines 3 (MX Blues), Razer BlackWidow 2013 Ultimate Mouse: Corsair M90,M65 w/ Vengeance MM600
Since you've burned through a lot of mouse pads already I can recommend you the one, which I'm using right now. I know it's a bit more expensive, but it's really worth it. The mouse pad is Razer Megasoma. This pad is made of silicon, which makes it absolutely indestructible. You can wash it, abuse it and burn it (resist up to 400C). Once put on the table the pad is just so firm and strong as if it were to be made of steel. The old version, which I have is white and the newer version (Megasoma 2) is black, but they are practically the same unit just with different colors. The price for this unit is 49.99$ in most stores. As I said it's not cheap, but in my opinion is way better than all those other mouse pads for 30$.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
Woops seems you made a double post :P Anyway thats pretty cool I didnt know that I might get that too
Specs of my PC:
CPU: AMD FX 8350  Motherboard: Gigabyte 990XA UD3  GPU: Gigabyte GTX 770 Windforce 2GB  HDD: WD Green 2TB SSD:  Corsair Force GT 120GB SSD RAM: Corsair 8GB(2X4) PSU: CoolerMaster G650M
