Hello,
I am currently planning a build that will be used for gaming, 3D rendering/sculpting/painting, and heavy 2D work in programs like Photoshop. I am equipping it with 32Gb of ram initially, and will add another 32 if necessary.
My current question is, would I notice a performance difference between these two kits?
https://www.newegg.com/Product/Product.aspx?Item=N82E16820231964
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232475&cm_re=Trident_Z_RGB_3000-_-20-232-475-_-Product
If I go for the cheaper modules, I will try to overclock them as far as I can, though I imagine CAS will take a hit fairly early on. I will also watercool them, since I will be running a custom loop, so I imagine there will be no heat problems due to overclocking, but before you veto that idea, do note that I will be watercooling the RAM for purely looks, and any cooling benefits will just be an added bonus.
Thank you
