CPU power connector
Go to solution Solved by MedievalMatt,
Just now, triagonal_mouse said:
Will plugging in the 4 pin cause any damage or is it just extra power that wont damage the cpu
All the EPS connector does is supply an Auxxilary current to the motherboard.  typically for PCI-E power or for CPU power.
for CPUs it is there for more even and clean power delivery.  Adding more cant hurt AFAIK, it will only draw the power that is needed from what i understand.
If your Motherboard has an EPS power connector near the CPU socket, yes, you need it.  No questions.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
https://linustechtips.com/topic/763015-cpu-power-connector/#findComment-9641380
Except for the small amount of motherboards that have an 8-pin EPS AND a 4-pin EPS, where the 4-pin isn't required. but yes, you're right 99% of the time.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/763015-cpu-power-connector/#findComment-9641423
https://linustechtips.com/topic/763015-cpu-power-connector/#findComment-9641437
True, but typically those boards have that extra 4- PIN for PCI-E power, or for extreme overclocking.  However, i see your point.  Personally, id still plug those in.  Cant hurt anything.
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
https://linustechtips.com/topic/763015-cpu-power-connector/#findComment-9641440
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
https://linustechtips.com/topic/763015-cpu-power-connector/#findComment-9641448
Alright thanks for letting me know
https://linustechtips.com/topic/763015-cpu-power-connector/#findComment-9641457
