I'm putting together a computer for my mother to use as her daily pc and to function as our home storage setup and want to build a raid 5 array for redundancy and efficiency using  2tb wd blues.
https://www.amazon.com/Blue-Desktop-Hard-Disk-Drive/dp/B013QFRS2S       - 2tb
I just want to make sure that if i order 3 of these drives that i can configure them to raid in windows 10 and have 4 tbs of space total. If im right, one drive can fail and all of my data will still be there.
Am I right?
R5 1600, Asus Prime B350, 16gb corsair vengeance, nzxt s340, gigabyte gtx 1060, cryorig h7, 256gb adata su800. More in Link.
https://pcpartpicker.com/list/RC4KQV
https://linustechtips.com/topic/763008-home-storage-advice/
Am I right?
Yes, you are right.  Although the total space will be a bit less than 4TB (as reported in windows) because each drive is a bit less than 2TB (as reported in windows).
For a RAID array the REDs are a (very slightly) better choice than the BLUE's.
https://linustechtips.com/topic/763008-home-storage-advice/#findComment-9641314
why are reds better than blues? is it worth the larger cost?
https://linustechtips.com/topic/763008-home-storage-advice/#findComment-9641391
