There are really only two things I am not sure about. I am on PC Part Picker and put in the mobo and CPU and a compatibility warning came up.
The CPU I chose is AMD FX-6300 3.5GHz 6-Core and the MOBO I chose is Asus M5A97 LE R2.0 ATX AM3+ Motherboard
It read, "Some AMD 970 chipset motherboards may need a BIOS update prior to using Vishera CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions."
I have no idea what this means. Please help!
https://linustechtips.com/topic/762920-please-help-with-compatibility-issues/
It's fine, the Mobo should be updated when you get it if not and you have a old PC or something you can get the BiOS update there just look up how
Please @Dormant God or quote me if you want me to see your message/reply
        Custom PC Specs
Custom PC Build: (CPU) i7-6700k (MotherBoard) GIGABYTE G1.Sniper Z170 SLI ATX (RAM) 16 GB Dual Channel DDR4/3000MHz (GPU) MSI GTX 1080 (Case) Crystal 570X RGB (Storage) 1 TB HDD from Seagate
No problem
        Custom PC Specs
