2 minutes ago, Terminator7577 said:
Budget is around $720 USD https://pcpartpicker.com/list/4Tq2f8 Is it a good build? Note: before you give me a new part list please do not change the case, fans, or fan controller.
You do not need to buy fans or a fan controller. Your motherboard can control the fans and your case already comes with some fans adding a few more won't do all that much performance wise.
Then with that gone you can use that money either to get a better CPU or and SSD.
https://linustechtips.com/topic/762868-first-build/#findComment-9640016
Pc Specs
CPU: I7 6700k 4.5Ghz  Motherboard: Asus Z170-A Ram: Corsair Vengeance 16GB DDR4  Cpu Cooler: Corsair H100i v2  Storage: Crucial MX300 525GB/Hitachi Deskstar 3TB  Graphics Card: GTX 1080 Founders Edition Case: Corsair 750D Power Supply: EVGA SuperNOVA 850w Keyboard: Corsair k70 Mouse: rival 300
https://linustechtips.com/topic/762868-first-build/#findComment-9640081
PCPartPicker part list: https://pcpartpicker.com/list/9hhnFd
Price breakdown by merchant: https://pcpartpicker.com/list/9hhnFd/by_merchant/
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  ($188.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler  ($15.88 @ OutletPC)
Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard  ($58.00)
Memory: Avexir Core Series 8GB (2 x 4GB) DDR4-2400 Memory  ($64.97 @ Jet)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: Asus Radeon RX 480 4GB Dual Video Card  ($188.99 @ SuperBiiz)
Case: Deepcool DUKASE WHV2 ATX Mid Tower Case  ($59.99 @ SuperBiiz)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($53.99 @ Amazon)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($29.99 @ SuperBiiz)
Total: $709.69
Generated by PCPartPicker 2017-04-06 14:33 EDT-0400
Get windows from Kinguin for aroung $30ish
https://linustechtips.com/topic/762868-first-build/#findComment-9640095
