So i have this User Form in Excel i've created by clicking on the blue button.
Right now i have all available times showing in the Start Time list in the user form
The feature im trying to implement is when in the user form, when you make all your selections and make the field selection, based on that selection in the user form if that field location is listed on the excel spread sheet then the time block that is allocated for it (from start time to end time) will be removed from the Start Time section in the User Form.
The picture i've added just shows what it would look like. And if you selected a different field it would update the list again.
Any help would be much appreciated,
thanks,
Scheduler Import.xlsm
https://linustechtips.com/topic/762039-excel-vba-help/
