Hypothetically, if I were to put my computer in the refrigerator. Note: It's aircooled. Would I see any significant improvements? My cpu is over clocked pretty high and so is my graphics card. Because if it would work. I'd rather just buy a mini fridge and then I would plop my computer in.
https://linustechtips.com/topic/76180-serious-question-here-about-cooling/
it would, but moisture would kill it
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
Yes, until you open the door by accident, something condenses and BOOM!
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
While this doesn't sound very practical. You will have to worry about condensation building up on the components
CPU: Intel Core i5 2500K | Case: Bitfenix Prodigy | Motherboard: GA-H61N-USB3 | RAM: Corsair 8GB 1333 MHz Video CardEVGA GTX 660 Superclocked 2GB DDR5
Power Supply: Corsair CX 430 | SSD: Samsung 840 120GB | HDD: 2X Seagate Barracuda 500GB 7200rpm | Monitor Asus PB238Q & Asus PB278Q
Mouse: Lenovo N50 | Keyboard: Apple Pro Keyboard | Operating Systems: Hackintosh OS X 10.8.5 & Windows 8.1
What he said :)
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
Condensation would be a major problem. Theoretically if you could rig a dehumidifier on to it, and make it the intake air, it could work. But that would probably make the fridge burn out in no time
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
if this would work alot of people would already be doing it...
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
Condensation. It will kill it. Don't bother. Get an air conditioner and keep the room COLD.
I don't think it would go boom.
Killjoy...
Also OP, don't sell yourself short. Stick it in the deep freeze if anything.
The compressor on the fridge might not be able to keep up with the heat output of your computer, then your fridge would heat up and have no where for that hot air to go, then your fridge would be hotter that ambient temperature.
If it could, how would you route your power cables?
My dreams have been crushed. I didn't take moisture into account.
CUT A HOLE IN DUH
Im kidding
Your pc would die but yes. It would go from temp+ x (x= ambient so lets say 20) to temp+ x (ambient in a fridge so let's say 0) It would be temp+ 0 =
If your ambient goes up 5 degrees your pc gets 5 degrees hotter if it gets colder it's the same thing.
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
you could get a higher overclock (maybe) because the cooler the cpu the less voltage it needs.
and everything would last longer. I would try it with those silicone humidity-killers or what you wanna call them. those things that come with hardware that say you should not eat them. :D
        wow... pretty empty here...
FYI, silica packs don't absorb moisture indefinitely. Once they're full, they need to be "recharged" by heating them in an oven for several hours in-order to reactivate them. So no, it would not work in this situation.
but for a day it would work, right? just enough to try it out :) keeping your pc in a fridge clearly isn't a 24/7 option.
