Adapter allows connection of fitting with G1/4" threads to extend tubing possibilites in your water cooled system.
EK-HD PETG Tube 10/12mm 500mm
Also, with the tubing it said: For expert users only!
*EDIT: I would also suggest using a left angle fitting, not the right angles. Those seem to leak more often.
I don't know the conversions and what translates into what. I can read the expert users only
7 minutes ago, jorge97 said:
Hi guys
I seemed to of posted alot.. sorry
Final one I hope...
Is this fitting ( https://www.ekwb.com/shop/ek-af-angled-90-g1-4-nickel ) compatable with this tube ( https://www.ekwb.com/shop/ek-hd-petg-tube-10-12mm-500mm-2pcs ).
Thanks
It's just an angled adapter you still need the hardline compression fitting itself.
https://www.ekwb.com/shop/ek-hdc-fitting-12mm-g1-4-black-6271
There isn't a left angle fitting. They're both the same. So Don't try take me for an idiot. All I asked was to see if they we're both compatible
System: Ryzen 7 5800X - Gigabyte X570 Aorus Master - Noctua D15S Chromax - 32GB 3600 RAM - EVGA Black 2080Ti
