I'm currently building a new pc and want a good silent option for a modular power supply. I plan to over clock with this setup.
-Asus hero vi
-i7 4770k
-asus gtx 780
-16gb Kingston hyper x red
-dark rock pro 2
-kingstong hyper x ssd 240gb
-a few storage devices
-alot of fans as I won't be liquid cooling this build since it will be a mobile work bench moving from place to place.
What size of power supply would you suggest 750? And what are my options for a silent modular psu?
https://linustechtips.com/topic/76150-help-with-psu/
Budget ?
With no budget i recommend a Corsair RM series PSU
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/76150-help-with-psu/#findComment-1044481
Cooler Master V850 or Corsair RM850 ? 850W might be a lot but well, you can't get any better for the money. And yes 750W is just fine :D
VIDEO GAMES                                  Max Power Build Log
https://linustechtips.com/topic/76150-help-with-psu/#findComment-1044485
BTW welcome to the LTT Forum, may you enjoy your stay :)
https://linustechtips.com/topic/76150-help-with-psu/#findComment-1044486
-Asus hero vi
-i7 4770k
-asus gtx 780
-dark rock pro 2
I'd say unless you want to SLI go for the 650 Watt Corsair RM Series one. If you want to SLI go for the 850 Watt one.
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/76150-help-with-psu/#findComment-1044487
if you wont SLI get a 650 watts unit, cant go wrong with corsair, noise blocker (these are pricecy but are real quiet) or any other know company, or look into a 550watts pasive unit (wont OC alot with that)
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/76150-help-with-psu/#findComment-1044493
Budget would be under 180 after tax which for me is 5% it was looking at the 750rm is that enough?
Thank you very much everyone I never thought this forum would be so quick and so helpful. 850rm I will look into since I might add sli in the future.
Overkill.
If you want to sli, the rm750 is plenty. If not, a decent 550w would be plenty.
https://linustechtips.com/topic/76150-help-with-psu/#findComment-1046029
corsair-ax860i-or the seasonic-platinum-860w
Check prices online . Provantage.com sometimes has good prices.
Overkill unless you want to watercool 2 290's.
https://linustechtips.com/topic/76150-help-with-psu/#findComment-1047044
