I got the last part of my storage server today, 2720SGL and slapped it into the rig and connected 6 3TB drives in JBOD.
The drives appear in windows as they should after the drivers are installed and all seems okay as can be seen here.
I attempted to create a storage pool and again, the drives show up as they should;
However on EVERY attempt I get the following error;
I'm not exactly sure what to do as I can format the drives individually and have them show up in explorer, I can even create a spanned volume using all the disks but they REFUSE to go into a pool.
Windows will only put Disk 0 into the pool. Before installing Windows 8.1 I tried to use Windows Server 2012 and it would only show Disk 0 under logical devices, hence trying Windows 8.1 which I thought would work since I could see all the drives.
EDIT: I gave the free version of unRaid a go and it all seemed to work okay, the only problem I have with this is that I have read that storage spaces is more flexible with adding drives and obviously I will be able to use Windows on the machine with storage spaces which is a plus as I can do more things than just serve files.
Any help would be GREATLY appreciated, I don't think it's the RAID card as I seem to be able to do everything else with it so I'm not sure what gives.
Thanks, peeps :D
https://linustechtips.com/topic/76140-storage-spaces-not-playing-nice/
my guess would be that they're not all connected to the same sata controller....
Grammar nazis are people too!
Treat your local grammar nazi nicely and he might teach you a thing or two. (Note that I'm Belgian and not a native English speaker.)
Chivalry isn't dead!
hmm did you turn them into dynamic disks first?
Edit:  I just looked at the image.  Right click and turn them into dynamic drives or whatever I cannot remember.  Then it should work.
Thanks this is one thing I didn't try which I shall give a go when I go home, why was disk 0_0 going into a pool as it wasn't set as dynamic though?
I hope it does work as I don't have the patience to return the card, get another and just be stuck with this issue.
It's worth noting that I have tried Powershell and creating a pool with 0_0 and then attempting to add disks, both failed.
