Okay, I have a Steelseries H Wireless headset. The Optical Audio cable is plugged into my PS4 and the mini USB is plugged into my PC. This means I can get audio from both devices, which is useful for streaming.
My question is; is it possible to split the optical audio cable so I can use optical audio on my PS4 and PC at the same time? That way I can have good sound on both.
Even if it isn't at the "same time" is there some sort of splitter to save me changing the USB/optical audio cables around everytime I want to plug the headset into different devices?
https://linustechtips.com/topic/760097-is-it-possible-to-split-optical-audio/
1 minute ago, Celios said:
I'm guessing that wouldn't allow me to use optical audio on two different devices at the same time though, right?
Is there a switch for mini USB too?
https://www.amazon.com/UGREEN-Sharing-Peripheral-Switcher-Adapter/dp/B01CU4QCRS/ref=sr_1_2?s=pc&ie=UTF8&qid=1490976744&sr=1-2-spons&keywords=usb+switch&psc=1
6 minutes ago, Schakal_No1 said:
and yes, you cannot use them at the same time. You would need a mixer board for that
Okay, I see.
So would this work?:
Steelseies H Wireless base - mini USB to USB switch - USB 1 to PS4 - USB 2 to PC
And then:
Steelseries H WIreless base - Optical Cable to Optical Cable switch - Optical Cable 1 to PS4 - Optical Cable 2 to PC
That way I can switch between my PC and PS4 without changing any wires, I would just have to switch the two switches, right?
