WILL IT WORK??
Go to solution Solved by Sniperfox47,
2 minutes ago, Akash Rock said:
If i setup a I5 7600K IN B250 . WILL IT WORK IN NON OC MODE I MEAN WILL IT RUN AT NORMAL GHz?
There's no need to type in all capitals.
Yes.
A K-series processor can only be overclocked in a Z-series board. Other than that any 7th Gen I3,i5, or i7 will work with any 200 series chipset.
Yes.
https://linustechtips.com/topic/758942-will-it-work/#findComment-9591999
12 minutes ago, Akash Rock said:
Bro if i need to Turbo boost a i5 7600k , should it need to be overclocked ?
I am not a good english person . I am from another country . so i am sorry for my english
Turbo boost is seperate from overclock. You do not need to overclock to get the turbo boost speed. You just need a good enough cooler.
https://linustechtips.com/topic/758942-will-it-work/#findComment-9592220
