So i'm looking to build my first pc, however i have no idea how to make sure all the parts i have selected are compatible with each other, or even if all the items that i need are in my list. i'm going to watch step by step tutorials on how to build it when it arrives, i just want to make sure it will all work before i buy it, and also if i'm missing anything please let me know, thanks!
Case: Phanteks Eclipse P400 PH-EC416PTG_BR
Motherboard: ASUS PRIME Z270-A LGA1151 DDR4
GPU: EVGA GeForce GTX 1080 Ti FOUNDERS EDITION GAMING 11GB GDDR5X
CPU: Intel Core i7-7700K
CPU Cooler: Cooler Master V8 GTS
Thermal paste: Artic Silver 5
Ram: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz
Power Supply: CORSAIR RMx Series RM750X 750W 80 PLUS GOLD
Monitor: ASUS MG28UQ Black 28" 1ms (GTG) 4K UHD
https://linustechtips.com/topic/758674-need-help-with-my-build/
8 minutes ago, deXxterlab97 said:
Wait for aftermarket 1080 Ti, cheaper, quiter and cooler
You'll be fine with 650w PSU
Rest is solid though, I doubt you'll find cheaper stuff without sacrificing performance
My overall budget for my build will be around $4000 Canadian, i just want to make sure i'm getting the most bang for my buck, and i went for the 850 just in case i want to add another 1080 ti in the future to boost performance. i know whats good for basic things like gpu and cpu, other than that i just find things that look cool and add them to my list. but like i said before, i want the most bang for my buck, i'd take performance over aesthetics any day, besides the case, i really like the whole tempered glass concept. just dont know a good tempered glass case, found that case on google, 1st result under tempered glass gase lol.
https://linustechtips.com/topic/758674-need-help-with-my-build/#findComment-9588838
To give you an idea of the P400 case. Here are both of mine.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/758674-need-help-with-my-build/#findComment-9589219
