When running Skyrim through Mod Organizer's SKSE selection from the dropdown menu (installed like Gopher did), windowed mode works fine, but when I run in windowless mode, I get an endless black screen.  I have no idea what might cause this.
Vanilla Skyrim runs in both windowed and windowless.  Neither of my mod profiles run in Windowless (no matter the resolution), but they do run in windowed.
Thank you for any and all help/comments.
Royal Rumble: https://pcpartpicker.com/user/N3v3r3nding_N3wb/saved/#view=NR9ycf
"How fortunate for governments that the people they administer don't think." -- Adolf Hitler
"I am always ready to learn although I do not always like being taught." -- Winston Churchill
"We must learn to live together as brothers or perish together as fools." -- Martin Luther King Jr.
https://linustechtips.com/topic/758568-help-with-skyrim/
VanillaSkyrim runs in both windowed and windowless.  Neither of my mod profiles run in Windowless (no matter the resolution), but they do run in windowed.
Buggiest game ever, that's probably why, just run in borderless windowed mode.
Laptop: Asus GA502DU
RAM: 16GB DDR4 | CPU: Ryzen 3750H | GPU: GTX 1660ti
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9587697
It doesn't support 1440p in windowed mode, I don't think, so I'm stuck with this:
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9587912
Try editing the resolution in skyrimprefs.ini, I had to edit mine to get it to be 21:9
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9587915
Alrighty.  I'll try that.  Thanks.
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9587929
Since you mentioned SKSE, I'd presuming we're talking Oldrim (2011) here.
I personally run and manage my mods with Nexus Mod Manager (newest version always, most folks who've had problems with it were running very old versions) and have no problems running Skyrim at 2560x1440 Borderless Windowed - Once set up as such through the vanilla Skyrim launcher program (SkyrimLauncher.exe inside the Skyrim install location).
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9589214
11 hours ago, MoonSpot said:
Just a reminder that Mod Organizer has it's own ini files for skyrim that you might want to look at instead of just to ones in the skyrim folder..
Ah, thanks, because me editing the display height and width in skrimprefs didn't work.
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9590592
Yeah, the launcher only has options for 1440p when in windowless mode.  Windowed goes up to 1080p.  That is for me, at least, but there's no reason we should be different.
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9590635
It didn't work.  I've been advised to check in MO's files, so that's what I'll do.
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9590720
Question; Why are you running it in windowed mode? Why not run it in full screen?
FWIW, I'm running modded Skyrim in full screen 1440p DSR on a 1080p display.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9590900
It's in the OP, "When running Skyrim through Mod Organizer's SKSE selection from the dropdown menu (installed like Gopher did), windowed mode works fine, but when I run in windowless mode, I get an endless black screen. "
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9592231
'Tworked.  Thank you.
If anyone has any idea about the fix for the windowless mode endless black screen, it'd be greatly appreciated.
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9592464
Ah, I misunderstood. By "windowless" you mean "full screen". I got it. ;)
Unfortunately, I'm not sure what could be causing this problem. The game is extremely buggy as it is. Sometimes I have to start the game, then exit and re-start it again for all my mods to load properly.
My Systems:
F@H Rig:
HTPC:
Laptops:
NAS:
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9595929
Yeah, sorry, I probably should've made that more clear.
That's pretty much the answer I've gotten so far from everyone.
https://linustechtips.com/topic/758568-help-with-skyrim/#findComment-9595937
