well im pretty sure you could do something with ITX if you are on the Intel platform. you can do this with GPUs with dual BIOS setups but im pretty sure that shit would break if you sudenly swap your BIOS durin operation. IXT would allow you to have a saved profile in the OS you can apply but if you are looking for a physical switch you are out of luck unless you do some tinkering with an Arduino and some USB cables or something
Builds:
https://linustechtips.com/topic/758277-setting-up-a-switch/#findComment-9584549
