38 minutes ago, javedhaujee said:
For case fans which is better the AF or SP series from corsair, am talking exhaust fans and not radiator or  near heat sink.  Pls help
Can't go wrong with a coolermaster 120mm fan 4 pack
lower db than the AF120 I'm seeing
https://www.newegg.com/Product/Product.aspx?Item=N82E16835103052
You're probably going to want airflow for an exhaust fan, though for the most part you probably don't even need an exhaust fan
https://linustechtips.com/topic/758247-case-fans-pls-help/#findComment-9584309
Just throw a 80 or 92mm Vantec Tornado back there for that lol. Seriously, don't unless you want to sound like a server farm.
i5 6600k @ 4.4ghz on Hyper 212 Evo
Powercolor RX 480 8Gb Red Devil @1330Mhz
Bottom line:  Don't be a spaz or an 800lb gorilla when installing your expensive CPU, and you won't have any problems. --Phate.exe
https://linustechtips.com/topic/758247-case-fans-pls-help/#findComment-9584947
May I question, what potentially would be your preference? LED Illumination, low noise output, ect?
Although, personally I would upmost certainly recommend of these few [UK Links]
http://eu.coolermaster.com/en/cooling/case-fan/masterfan-pro-120-af/
https://www.amazon.co.uk/Auoker-120mm-Case-Fan-Pressure/dp/B01M1HYD86?th=1
https://www.overclockers.co.uk/be-quiet-silent-wings-3-120mm-high-speed-fan-fg-03b-bq.html?gclid=Cj0KEQjwk-jGBRCbxoPLld_bp-IBEiQAgJaftafoZN1h0DVCXcV93eP0k96Iv8k0_N5RL1VOuzYNRMYaAoRI8P8HAQ
http://www.fractal-design.com/home/product/casefans/venturi-series/venturi-hp-12-pwm
I use of those Auoker fans quite often, highly recommended for a spectacular balance between noise emission, as well as airflow movement [CFM].
Would not use Corsair fans unless you desire brilliant quality bearings/motors.
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/758247-case-fans-pls-help/#findComment-9591364
Those are crap.
Specs cannot be reliably compared between different manufacturers. There's no regulation on how fan specs are measured. For the most part, they are bull. Ignore them and look at benchmark and in-depth reviews instead.
AF120's are better than SP120's in most cases that aren't highly restrictive like a rad. That being said, Corsair AF/SP fans tend to hold a premium over other similar or better performing fans.
On 3/26/2017 at 11:23 PM, javedhaujee said:
Thanx, my case is nzxt s340 elite am going to replace the rear and upper fan so Sp 120 quiet or high pressure ones.
What's the reason behind replacing the case fans?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/758247-case-fans-pls-help/#findComment-9592641
  • 2 weeks later...
On 3/28/2017 at 1:59 PM, WoodenMarker said:
Those are crap.
In what way? They're basic 120mm fans that will get the job done.
https://linustechtips.com/topic/758247-case-fans-pls-help/#findComment-9641333
They don't perform well and aren't that quiet for the performance that it delivers. It's below average.
1 hour ago, ottoyu34 said:
Sometimes the cheapo CM fans can be quite decent surprisingly.
I tried the Corsair SP120 LED those were crap. Only ones that met my expectations was ML series in 140mm
SP120 LED's aren't great either but at least they're better than the CM R4's.
https://linustechtips.com/topic/758247-case-fans-pls-help/#findComment-9641784
