x370 mobo's going forward?
On 3/27/2017 at 9:05 AM, SpaceGhostC2C said:Because the AM4 socket supports CPUs with iGPU as well (like the A12 APUs). Same reason all mainstream Intel boards, from Sandy Bridge to Kaby Lake, have integrated video ports, regardless of form factor.
I don't understand the point about "wasting chipset": the chipset has nothing to do with it. There's no on-board GPU in these motherboards.
running lanes to the port pulls from what you can think of as a max capacity of included things, each pci lane, each sata port, each usb adds up and having a port itself also takes points in this regard, and the point about wasting is that I was previously of the understanding this was the high end chipset intended for high end boards likely meaning having the port was pointless for the target audience.
I've since learned that there's yet another chipset coming that's part of that "enthusiast" line making this the mid tier option in which case I can totally see people going with the r5's and actually using the igpu, less likely than perhaps the b350 but not unreasonable for maybe someone setting up an htpc
