Hello All,
I'm building a new i7-7700K system and I'm looking for a recommendation on the motherboard.  Some relevant information:
  • I'm planning to do a moderate overclock, nothing extreme, just a stable performance boost
  • My memory spec is DDR4-3200, I am planning to start with 2x16GB and would like to be able to expand to at least 64GB as necessary
  • I want the ability to install two M.2 SSDs in a RAID 0 configuration, while still having a PCI-E channel open for a high end graphics card
While I don't really have a limited budget, I'm also not in to spending $500 on a motherboard without gaining performance for my money.
I look forward to reading your suggestions! Thanks!
https://linustechtips.com/topic/758079-motherboard-recommendation/
