Hey LTT community!
So it seems I am having power delivery problems with my gpu. I actually do mean power (power input) not the usage of the gpu, where my usage would stay constantly high, but the power drops to around 53% and the game either permantently or temporarily freezes or it gets stuttery and i get this electronic interference sound thorugh my headphones and/or speakers. The thing is that this issue already occured previously but after a while it disappeared without me doing anaything and occured again maybe 2 months later without having changed any drivers or hardware which is really odd and this is going on since i built my pc basically. Though I just did a fresh install of the drivers but it didnt help. I read online that you could enable "power loading" in the BIOS settings to maybe fix this issue, but i couldnt manage to find it anywhere in the settings.
Would be awesome if you could give me some advice and help me with that!
thanks in advance,
Tiwaz
i5 4690k stock
evga gtx 970 sc stock (custom fan profile for lower temperatures, on standard it would target 79°C and with mine its 74°C)
Gigabyte Z97X-Gaming 3
4x4GB Kingston Savage 1600mhz cl9
Silverstone ST 750W 80+Gold (had a corsair cx600 before but it died after like 3 weeks :( )
Crucial 250gb m550 ssd
https://linustechtips.com/topic/757429-gpu-power-delivery-problems/
Start with the basics, reseat the graphics card & pcie cables, and/or try different pcie cables.
Fresh graphics driver
Are you sure it is a power issue and not a software issue?
The program freezing would cause the utilization to drop just as the alternative.
i7 10700k @ 5.1Ghz, 1.37v | Asus Z490-E Strix | Asus Rtx 2080ti Strix | 16Gb Trident Z Rgb @ 3600MHz | Samsung 970 Pro | EVGA Supernova G2 850w  | Corsair 500D | Celcius s36 /w ML Pro's
i7 8700k @ 4.8GHz, 1.31v | Asus Z370-A Prime | Asus Gtx 1080ti Strix | 16Gb Corsair Dominator Platinum | Samsung 850 Evo | Corsair TX 650W  | Corsair 750D | Corsair H100i v2 /w SP-120's
the power drops where temporary freezes or where it got extremely slow the whole pc for some seconds
Are you monitoring CPU usage and such when this occurs to roll out an issue with something running in the background?
