H110M-DGS no post
Go to solution Solved by PenPoint,
The very first possible circumstance is BIOS of the mobo hasn't been upgraded to the Kaby-supported one. To check this out, you must get any kind of Skylake CPU from somewhere.
I set about to build a very simple PC, just a g4560, a relatively cheap h110, from asrock. It is not my first build by any means thus I thought it might go flawlessly, but here I am now. I don't get a post and there is no power on the USB ports, but the fans spin up. This is strange. Any ideas? I can't really wait for a replacement of every single part, so I can pretty much only try to swap one part. I do not own an accessible GPU or a Kabylake/Skylake chip however, since my main system is a custom loop.
Any ideas how to go about?
https://linustechtips.com/topic/757427-h110m-dgs-no-post/
Pretty sure your going to need a skylake chip to get it to boot so you can update the bios.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/757427-h110m-dgs-no-post/#findComment-9575674
