Fan up or down?
By
itrue21
in Power Supplies
in Power Supplies
Solved by WoodenMarker,
Down is better for the psu. You don't want to do this if the bottom of the case doesn't have ventilation or filters though.
Up can take heat away from the gpu or the rest of the system.
It usually doesn't matter. Also, this really only applies if your case supports a bottom mounted psu.
Jimkirk363 ·
Posted in Windows0 -
Ramrod126 ·
Posted in Cases and Mods0 -
smush ·
Posted in CPUs, Motherboards, and Memory5 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6 -
Nebcs ·
1
FancyPants101 ·
6
1
