[Java] Need help writing an equals() method for a linked list
So the jist of it its, i have a User object that contains a username and a password. The there is a linked list that contains a list of users, i'm trying to compare the user object which holds the entered username and password with the ones in the list. If any of the user's in the list match then it should return true, currently i have a comparison but it doesn't work due to the equals needing an override method. Which i'm stuck on, any ideas? thanks.
Current comparison:
public boolean logOnSeller()    {
        Seller tempSeller = new Seller(username, password);
        for (int i = 0; i < userList.size(); i++) {
            if(userList.equals(tempSeller))
                return true;
        return false;
The problem being i think that the User object is being compared to the memory address of userlist rather than the individual elements in it? Thanks for any help.
PC Specs: i5 4690K, MSI GTX 970 Gaming, 16GB Crucial Ballistx Tactical at 1866Mhz, MSI Guard Pro, 120GB Crucial MX100, 4TB HGST HDD, NZXT H440 Black/Blue
Phone: Oneplus 3 w/ Moto 360 2nd gen
Consoles: New 3DS XL, Xbox One, Nintendo switch soon hopefully.
Just now, ShrDc said:
Can't you use userList.contains(tempSeller)?
Tried to but it provides the same result as .equals does.
You're trying to compare userList to tempSeller instead of userList item, and you're doing same comparison userList.size()-times. So if there are 100 user on the list, you will compare same thing 100 times. Since it is a linked list it has pretty high complexity to get item on a n-index so getting item from a list by get(index) would be not reasonable, as you do it in sequence, you should use iterator.
Other thing, are users unique by username? If so I would think about doing username:string => user:object map, so you could just check if user with that username exists in a map and then check if the password match, it will reduce complexity to be logarithmic. But that depends on if you really need linked list.
            if(userList.get(i).getUsername() == tempSeller.getUsername() && userList.get(i).getPassword() == tempSeller.getPassword())
                return true;
            else
                return false;
                return true;
            else
                return false;
Tried this but it's still returning false even when the data matches.
Yes users are unique by username, the linkedlist isn't a complete requirement but it's the prefered method i was asked for.
  import java.util.*;
  import java.lang.*;
  import java.io.*;
  /* Name of the class has to be "Main" only if the class is public. */
  class User {
    private String username;
    private String password;
    public User(String username, String password){
      this.username = username;
      this.password = password;
    public String getUsername(){
      return this.username;
    public String getPassword(){
      return this.password;
    @Override
    public boolean equals(Object other){
      if(other instanceof User){
        if(other == null || !(other instanceof User)){
          return false;
        if(other == this){
          return true;
        User otherUser = (User)other;
        return (this.username.equals(otherUser.username) && this.password.equals(otherUser.password));
      return false;
  class Main
      public static void main (String[] args) throws java.lang.Exception
        LinkedList<User> users = new LinkedList();
          users.add(new User("A", "abc"));
          users.add(new User("B", "bcd"));
          users.add(new User("C", "cde"));
          users.add(new User("D", "def"));
          User userToCompare1 = new User("C", "cde");
          User userToCompare2 = new User("B", "fgh");
          if(users.contains(userToCompare1)){
            System.out.println("User exists.");
          } else {
            System.out.println("User doesn't exist.");
          if(users.contains(userToCompare2)){
          } else {
            System.out.println("User doesn't exist or wrong password.");
          //There is a map example if you're curious
          Map<String, User> usersMap = new HashMap();
          ListIterator<User> usersIterator = users.listIterator();
          while(usersIterator.hasNext()){
            User user = usersIterator.next();
            usersMap.put(user.getUsername(), user);
          if(usersMap.containsKey(userToCompare1.getUsername())){
            User user = usersMap.get(userToCompare1.getUsername());
            if(user.getPassword().equals(userToCompare1.getPassword())){ // or user.equals, but name is already equal.
            } else {
              System.out.println("Wrong password.");
          } else {
          if(usersMap.containsKey(userToCompare2.getUsername())){
            User user = usersMap.get(userToCompare2.getUsername());
            if(user.getPassword().equals(userToCompare2.getPassword())){ // or user.equals(userToCompare2), but name is already equal.
            } else {
          } else {
Runnable version: https://repl.it/Gb4v
So there is an example how you override equal function of an object, so LinkedList contain will use it.
This makes me think this operator uses full equivalence. Or it's not actually comparing the value, but the objects themselves. I recall this being a funky thing in C#
17 minutes ago, Mr_KoKa said:
  import java.util.*;
  import java.lang.*;
  import java.io.*;
  class User {
    @Override
          return false;
        if(other == this){
          return true;
      return false;
  class Main
          } else {
          } else {
            } else {
          } else {
            } else {
          } else {
Thanks alot for your help. That solved the problem perfectly, that was a great explanation.
On 3/24/2017 at 0:00 AM, Mr_KoKa said:
it returns false because String is an object and should be compared with equal, other way you compare addresses.
Right, forgot about that. Used to python now, didn't use java for almost a year.
  • 3 weeks later...
