Hello,
Is it possible to plug my monitor directly to Motherboard's VGA but still uses the GPU's power(connected to motherboard)?
I have some issue with the VGA display in my GPU. and my monitor doesnt have a dvi/hdmi. (tried buying vga-hdmi but it ddnt solve the issue).
is there any software that will allow me to uses the motherboard vga port for my monitor? but still uses the performance of my gpu?
THNX
https://linustechtips.com/topic/756206-gpu-connection-question/
12 minutes ago, Ranz said:
Hello,
THNX
What's the point anyway.
https://linustechtips.com/topic/756206-gpu-connection-question/#findComment-9561704
