Hey
I currently have a cooler master G650M powering my i7 4790 and gtx 960 plus a few hard drives and 24gigs of ram. I am not particularly satisfied with the unit, and would like to change it out since I have generally gone for quiet components elsewhere in my build and I value silence over many other things. I can get a decent deal on a Corsair RM750X PSU, which is better quality and has their zero fan rpm when under low load thingy wingy. I am fully aware that it is waaayyy overkill for my current system in terms of wattage, but I kinda want it to make sure I dont have to buy yet another PSU if I decide to run something more demanding. I was wondering if it would be a bad idea in any way to use a high wattage power supply on relatively low demanding parts, other than the fact that efficiency probs wont be optimal and whatnot. Also, it would take more load to have the zero rpm fan mode thing ramp up, right? Making it more quiet overall?
I'm just asking cuz PSUs arent my strong side :)
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
https://linustechtips.com/topic/755715-psu-help/
I don't know about the other stuff but this in particular is not a problem. The PSU will only supply as much power as the parts draw. It might be able to supply 750W but if your parts only need something like 500W or whatever it is they actually need then the PSU will only give them that amount.
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
https://linustechtips.com/topic/755715-psu-help/#findComment-9556360
Yup, everything you said makes sense except
to which the answer is no, not at all. The more watts, the less likely your fan is going to turn up
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/755715-psu-help/#findComment-9556366
Well you might not make the best use of the efficiency of the unit since you won't be drawing around 55-65% with this set up, but since it has a low wattage zero load mode it might be a bit silent, so might as well go for it.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/755715-psu-help/#findComment-9556374
Thanks<3
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
https://linustechtips.com/topic/755715-psu-help/#findComment-9556375
He might get slightly less efficiency out of his load, but not a big deal.
https://linustechtips.com/topic/755715-psu-help/#findComment-9556378
