Hi everyone,
So i need some help for work -
We are getting a new Server to run our Navision Database:
here is the issue, I am only allowed to use Dell and i am Only Allowed £20,000 on this machine. It has to deal with a alot of data.
Can provide more information if needed.
Hayabusa
https://linustechtips.com/topic/755569-help-with-server-build-for-navision-database/
Not nearly enough information such as:
  • Assuming high IOPS is your goal, how much are you pushing currently?
  • How much throughput?
  • How many users?
  • Disk capacity required?
  • Cores required?
To be honest the fact you are asking this question on here worries me for your business. You would be better of speaking to someone from Dell directly who will be able to assess your needs and requirements.
System/Server Administrator - Networking - Storage - Virtualization - Scripting - Applications
  • How many users?
  • Cores required?
I'm just an IT Support Analyst not the one with the final say, I have been given the task to mock up what the best we can get with our budget - This will be going back to Dell and there will be much to and throwing.
Hayabusa
  • How many users?
  • Cores required?
Through a bit of searching I have found this forum thread: http://forum.mibuso.com/discussion/63463/best-hardware-specifications-for-nav-server
"  Microsoft has run benchmarks (NAV 2013 R2) with 500 users on a 4 core server with less memory. They are recommending around 125 users per core. I tend to be a bit more conservative and spec around 50 - 75 users per core. "
Quack 🦆
Acutally I have just found the offical sizing guide for NAV. Use that as your baseline. Link appears to be dead, but it will be out there :P
https://mbs.microsoft.com/customersource/Global/NAV/learning/documentation/system-requirements/Hardware_Sizing_Guide_for_Dynamics_NAV_50
Quack 🦆
