Hey guys,
New member, but probably a very tired question. I tried to find previous topics/posts that addressed this, but I wasn't really finding much with the forum's search function. Maybe user error.
I am a novice builder getting ready to put together my first real PC (Mac convert). I don't have an anti static mat, but don't want to work on a bare/hard surface. I do have a very large mouse pad. I just want to make sure that is a perfectly fine surface to work on/place some of the more sensitive components (like the motherboard) on, without worrying about physical or electrical damage to the parts.
I don't have an anti-static wrist band, but could get one easily, people seems to be torn on whether that is overly cautious or a foolish-to-ignore necessity, and my intention was to plug in my PSU and periodically touch the back-plate of that to ground myself throughout my build.
Before I get started I just wanted to make sure, from a community with experience, that that was going to be adequate practice/environment, and that surface was going to be fine to work on
Sorry if you all get this a lot, and thank you for any information, caution, horrorstories
Justin
https://linustechtips.com/topic/755290-mouse-pad-as-build-surface/
I have built on carpet many times with old and new components. Nothing has died. That being said, it wouldent hurt to use a runner bottom mouse pad or your motherboard box as a surface while pre-building (outside case) to test everything. Besides that, if you are woried than just touch a plugged in (but switched off) power supply every now and then while building.
Even with my (IMO) extensive knowledge of computers, I still use an anti-static wrist strap, even when working with hardware I barely care about.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
