Hello, I currently own a Lenovo H50 2014(http://shop.lenovo.com/us/en/desktops/lenovo/h-series/h50-intel/#tab-tech_specs) i would like to put a graphics card in it because it's currently running with on-board graphics it has a 180w power supply i want to also replace it i know the mother board has a pci express x16 slot i'm not sure what to do since this will be my first time doing anything like this and dont have much of a budget,also i dont really want to play games at super high resolution or fps running anything at 60ps with high res would be enough for me i would like suggestion on what i should use to upgrade
https://linustechtips.com/topic/754884-need-help-on-a-upgrade/
Find yourself a cheap but reputable power supply (that has a decent rating. I think there's a PSU tier list somewhere on this site. 430W should be enough).
An RX 460/470 should work perfectly in your situation.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/754884-need-help-on-a-upgrade/#findComment-9546850
there is it is pined on PSU tab
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/754884-need-help-on-a-upgrade/#findComment-9546858
1 minute ago, nerdslayer1 said:
a gtx1050ti, gtx1050, rx460, your psu might not be enough.
no 180W is not enough for a i3 + any of those gpus
https://linustechtips.com/topic/754884-need-help-on-a-upgrade/#findComment-9546860
Just now, nerdslayer1 said:
180 watt is awfully low, i would get a higher watt psu to be safe.
you didn't read the OG post did you. I agree
https://linustechtips.com/topic/754884-need-help-on-a-upgrade/#findComment-9546867
