Help Speed Up PC?
While a cpu upgrade is definitely in order, at the same time, let's look at free solutions first. First thing I'd do is get CCleaner. Make sure not to delete cookies or saved passwords from your mom's most used browser, and run the main cleaner. Next, go to Tools>startup and disable any non-essential programs. If she still needs them, they can be opened up faster than they would open as a startup program anyways since you don't have 20 other programs opening at the same time. Finally, if she is willing to start from scratch, an SSD would also be a worthwhile upgrade. For a basic day to day office level computer (web browsing and document writing), an SSD will be one of your most noticeable upgrades.
EDIT: Also, while upgrading to Windows 10 on newer hardware would reap some performance gains, with an Athlon, your best bet is probably going to be sticking with windows 7
