So im planning on building my own pc. mostly because you get way more bang for your buck. so ive made my own build belov but i would like to hear your oppinion its gonna be used for gaming i would like to be able to run AAA titels at a persistant frame rate in high settings.
https://de.pcpartpicker.com/list/kfv79W
I have a budget around 1000 Euro and im from Denmark so i cant purches from the us without getting fies.
https://linustechtips.com/topic/754619-building-my-first-pc/
I would recommend this according to your partslists' price.
CPU: Intel Core i7-7700 3.6GHz Quad-Core Processor  (€312.43 @ Mindfactory)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  (€54.99 @ Amazon Deutschland) find out if the bios supports kabylake.
Memory: *Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  (€103.57 @ Amazon Deutschland)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive  (€81.03 @ Amazon Deutschland)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (€50.54 @ Amazon Deutschland)
Video Card: Zotac GeForce GTX 1070 8GB Mini Video Card  (€401.94 @ Mindfactory)
Case: Thermaltake Versa H22 ATX Mid Tower Case  (€33.99 @ Amazon Deutschland)
Power Supply: SeaSonic ECO 430W 80+ Bronze Certified ATX Power Supply  (€54.87 @ Amazon Deutschland)
Total: €1093.36
Generated by PCPartPicker 2017-03-19 17:02 CET+0100
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543895
1000 euro is 1.074,40 dollar :D
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543899
That is true. But he/she will have to pay so much for import tax..
I wanted to buy an RX480 from Newegg, the extra tax and shipping was an additional £80. (To the UK)
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543923
Case: CiT SPECTRE BLACK ATX Mid Tower Case  (€40.34 @ Amazon Deutschland)
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply  (€49.78 @ Amazon Deutschland)
Total: €1094.62
Generated by PCPartPicker 2017-03-19 16:58 CET+0100
Because no one got time for that BIOS update
Motherboard: Gigabyte GA-B250M-D2V Micro ATX LGA1151 Motherboard  (€74.94 @ Amazon Deutschland)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  (€103.57 @ Amazon Deutschland)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  (€77.49 @ Amazon Deutschland)
Case: Zalman ZM-T1 PLUS MicroATX Mini Tower Case  (€23.67 @ Amazon Deutschland)
Total: €1094.36
Generated by PCPartPicker 2017-03-19 17:06 CET+0100
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543925
Total: €1093.36
some guys over at reddit told me that i should get a 600 w power supply
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543940
Btw, both of these are out of stock, didn't notice the ram until after i edited the build so :P
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543943
Total: €1094.36
what do you mean by bios im tatally blank atm when it comes to pc building i only know some of the basics and how to put it together.
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543944
yeah if you dont know about inport taxes they can be a real bitch first time you order something and have no idea that they are there.
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543949
Nope. A very power-hungry 4960x overclocked to 4.5ghz with a gtx 1070 only ate 290w under load, no way you need a 600w psu for the gtx 1070.
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543950
The firmware for the motherboard, you will need it for the cpu to work with h110 motherboards. Try asking the amazon seller if it comes with a kabylake supported bios or ask them the manufacturer date for the mobo(november 2016 and later should support the 7700 just fine). Alternatively try finding a local computer store that can flash the bios for you.
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543966
ahhh ok
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543971
Total: €1093.36
and this build is the one you would recomend the most for my needs?
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543973
The bios update doesn't really take much time, if the bios flash i did some time back was anything to go by. Problem is finding the cpu to go with it but the computer store might do it.
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543974
Yes, although dexx's build will do just as well if you don't want to deal with the hassle/the seller confirmed the bios doesn't support kabylake, just take note that the ram and xfx proseries are both not in stock so replace those with something else.
https://linustechtips.com/topic/754619-building-my-first-pc/#findComment-9543986
