I have an fx 6300 with a gtx 1060, (upgrading cpu in a month calm down), and I was stress testing my CPU with AIDA 64 burn test, Prime95, CPU-Z, and OCCT, and noticed it never went above 50C with a stock cooler. The Mhz didnt go down. This is weird because last time i did it, i got into the 60's, I haven't changed my cooler, thermal paste, or overclock and suddenly it's much lower. Does anybody know why this is?
R5 1600, Asus Prime B350, 16gb corsair vengeance, nzxt s340, gigabyte gtx 1060, cryorig h7, 256gb adata su800. More in Link.
https://pcpartpicker.com/list/RC4KQV
https://linustechtips.com/topic/754414-weirdly-low-temps/
windows open in winter? O.o
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/754414-weirdly-low-temps/#findComment-9542202
Because it's happy like that?
better check if it's true with hwmonitor, coretemp and aida64 (three programs just to make sure it's correct)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/754414-weirdly-low-temps/#findComment-9542206
no, relatively similar ambient temps, ~2F dif at most. It's wierd bc i think it may be slowing something down, hurting performance.
https://linustechtips.com/topic/754414-weirdly-low-temps/#findComment-9542212
I used speccy, and all the ones u said (-coretemp).  I think that the chips sensors may be dying or something, bc these temps are too low not to be hurting performance or being wrong
https://linustechtips.com/topic/754414-weirdly-low-temps/#findComment-9542218
Did the weather become a lot colder since last time you checked? CPU temperatures scale one-to-one with the ambient temperature
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/754414-weirdly-low-temps/#findComment-9542227
No, not by more than 2F.
https://linustechtips.com/topic/754414-weirdly-low-temps/#findComment-9543847
10 hours ago, TheCherryKing said:
CPU temperatures can be very low when there is good cooling. My processors are usually around 36 degrees Celsius.
This is a stock AMD heatsink. It's not exactly a good cooler
https://linustechtips.com/topic/754414-weirdly-low-temps/#findComment-9543849
